Whilst running continuous analogue input acquisition, the -10846 overwrite error occurs in the AI buffer read vi. The scan backlog never goes above 5 and the error dosen't occur at any specific time during acquistion. (sometimes after minutes, sometimes over half an hour after starting the program).
The program originally worked correctley under Windows NT, but we are now trying to run it using the LabVIEW Real Time operating system, using a PXI-8170 embedded controller, NI-4472 Analogue acquisition card and 6527 digital I/O.
When first running it under Real time O/S, the number of scans to read had to be increased from 5 to 20 to stop buffer overwrite (the scan backlog did actually increase then).
The scan rate is set to 200, and buffer size 2000.
Any ideas what could be causing this problem?
