Are there examples of PCI DIO96 bidirectional IO?
I need to perform single byte read and write operations on a 8 bit bidirectional (Intel peripheral) bus using a PCI DIO96 and LabVIEW 6.02. I have been unable to configure a VI that works or find an example of using the 8255 Mode 2. Can someone point to an example?
(2,752 Views)
I couldn't find any examples either, but the important part is the configuration. In 'DIO Config.vi' or 'Digital Group Config.vi', select the input mode as bidirectional.
Their are several Knowledge Base entries that give information on using bidirectional mode. To search the on-line Knowledge Base go to:
www.ni.com >> Technical Documents >> Knowledge Base >> Search all entries
From there you can enter the keywords '8255' and 'bidirectional' to search on.
(2,752 Views)
