08-17-2011 07:12 AM
Hi all,
I now started with LabView programing and I have big problem how I make measurement overall vibration by ISO 10816 (I need velocity RMS in band 10-1000Hz). I try search on this forum, and I tryed many variants how measured this vibration, but I neither way I not trust on 100%. Can you please somebody help me?
Thanks.
David Student
Czech Republic
08-17-2011
07:42 AM
- last edited on
03-27-2025
11:09 AM
by
Content Cleaner
Consider using the proven Sound and Vibration Measurement Suite libraries, which build on LabVIEW's base RMS and integration techniques, and tune them to meet standards such as 10816.
https://www.ni.com/en-us/shop/product/labview-sound-and-vibration-toolkit.html
Alternatively, you will need to review the mathematical formulas behind the ISO standards.
Hope this helps.
08-17-2011 08:24 AM
Hi Preston,
We have Sound and Vibration Measurement Suite in our company, but i found only express function (RMS level) which is for conection to time signal. But i probably need some function for conection to frequency spectrum. I 'm create this string but i don't know whether is correct:
08-17-2011
08:52 AM
- last edited on
03-27-2025
11:10 AM
by
Content Cleaner
You should use the lower level VIs which give you much more flexibility. Consider the FFT functions, and the SVFA unit conversion VI.
The manual is located here.
Preston
06-08-2012 05:06 AM
Hi, I am attaching a vi developed for measuring vibration from single Accelerometer(100mv/g). It integrates the signal to get velocity and double integrates to get Displacement. Hardware used: cDaq :9174 , Module- NI9233. Once I calibrated the whole set up at about 1250 rpm. It was giving correct readings of all three parameters(Accln. , Vel. , Disp.) .As I go to higher rpm the readings are wrong.
As operating freq. of 9233 module is @21kHz, can I use it to measure the vibration of machine having rpm of about 7500 rpm?
I have taken sampling rate of 20ks/sec, Is it proper?
Pl. guide.
Sam
