Output the Y position of three separate cursors all with the same X position from a static graph
Hello All,
This should be a simple one, although nothing down the stretch of finishing up a vi seems to be simple.  I have an averaged plot with three spectra on it.  There are three cursors which are locked to one frequency.  I want to output the three Y position values of the three cursors.
Thanks in advance.
Ron
(1,242 Views)
Hi Ron,
what have you tried? Where are you stuck? Mind to attach your VI?
Suggestions:
  • Read the Cursor.List property - it's an array of cursor properties. Autoindex this array and read the Y position…
  • Set the ActiveCursor, then read its position. Repeat for next cursor…
(1,238 Views)
