LabVIEW Modbus Master and Slave
I need to program a master slave system in LabVIEW Modbus RTU. I am not very experienced in that and needs to improve. The master is a microcontroller CPU and the slave is also a microcontroller. I need to program the master slave communication in this, and I am looking for good examples to learn the same. Kindly let me know of any good master slave programming examples in labview. Thank You.
(2,110 Views)
The links below are good starting points.  You can find more with a simple search for "LabVIEW AND Modbus"
It's important to note that LabVIEW is typically targeted to a PC or an NI Real Time controller.
Modbus Communication Using LabVIEW or LabVIEW Real-Time Module
Introduction to Modbus using LabVIEW
Patrick Allen: FunctionalityUnlimited.ca
(2,081 Views)
