Output label text of selected Radio Button as string
I'm using LabVIEW 2011 version 11.0 (32-bit) on Windows XP.
Message 11 of 19
(4,327 Views)
Accepted by topic author wildcatherder
That "codeless" radio buttons is not a standard core LabVIEW control.  I did a google search for "radio buttons (codeless)" and found a few entries that seem to indicate it's a customized control that is installed with a LabVIEW add-on of some kind. If you could drop one in a blank VI, save it, and post it to this thread, we can see if there's a way to pull that string out some non-standard way.
Message 12 of 19
(4,326 Views)
You must be correct.  I remember adding some modules through the VPIM.  There is no simple way to distinguish these from the core controls, since LabVIEW recommends third-party controls be added to the standard palettes. I can only apologize for the wild goose chase.  I am withdrawing the question and will be able to work around this issue.
Message 13 of 19
(4,323 Views)
OpenG also provides these kind of controls?. I just wanted to know as I have never used OpenG functions
Message 14 of 19
(4,321 Views)
For anyone who does want to play around with this control.  I have attached it as Radio Buttons (codeless).  I wish I could attribute the source.
Message 15 of 19
(4,318 Views)
It's a modified slider.  Use the TextLbls[] property and index array to get the text.  Something like this, but an implicit property node is fine (the snippet tool unfortunately automatically converts it to an explicit one).
Message 16 of 19
(4,302 Views)
Thanks for posting the VI, wildcatherder.  And well done, nathand, in discerning that it's a slider control...I honestly did not consider that possibility when looking at the OP's screenshot.  I knew it was too old to be an XControl...I was trying to figure out how to do that customization with a text ring or something...never considered a slider.
And here's a screenshot (not a snippet) illustrating more clearly what nathand was mentioning regarding the use of an implicit property node to get the Text Labels:
Message 17 of 19
(4,293 Views)
Thanks for the solution and the additional information. I couldn't figure out how to get the slide refnum.
Message 18 of 19
(4,285 Views)
Not that certain individuals around here need more ammo, but the Icon View of the terminal in the screenshot earlier was actually a BIG clue as to what was going on.
Message 19 of 19
(4,281 Views)
