Output image in Labview using Matlab user define function
Hi all,
I have a case in which I take an input image ,use matlab function to process it and then output the following processed image . But how do I display that output image in Labview. I am using Matlab script in labview.Please let me know.
Ankit G
(5,267 Views)
Hi there, I believe that you are Calling the MATLAB® Software from LabVIEW. That being said, you can use the IMAQ ArrayToImage.vi to make things easier. This VI is part of the NI Vision Acquisition Software. Add it to your code, wire the data to the VI mentioned and create an indicator. I hope this helps
Alejandro C. | National Instruments
(5,255 Views)
Accepted by topic author AnkitG
(5,252 Views)
Thanks a lot Alejandro, it was helpful.
-Ankit g
(5,241 Views)
I need some help in the interaction between matlab and labview
(5,138 Views)
