Optimization of delay calc
I am developing an automation for a traffic test using the WinPcap example for Labview.
All that I need is to analyze traffic to get the delay between transmitted and received data, for that I have a sniffer that gets my data in two points and with WinPcap I can get the timestamp at those moments.
I have 2 ports receiving and transmitting data at the same time, in more than 10.000 frames/sec.
In the end of the test I have more than 1 million packets sent and with my current VI I am losing around 30% of packets because my VI is too slow for this amount of frames/sec.
When I have only 10 frames/sec I don't lost any packet.
I did many modifications already to make it faster (using the Initialize Array function with length of 3.000 only, instead of using the  Build Array function each packet I get, for instance).
I wonder if somebody can help me to find out other ways to make my VI faster.... Optimization 🙂
The main problem is in the Pase_Packet.vi and Cal_Delay.vi.
All the VIs find attached.
Any tip is welcome 🙂
Tanks for Support,
Thais
(2,425 Views)
Hello Thais,
Considering the amount and speed of the data that you're trying to receive (10KHz), you won't be able to perform it using LabVIEW in a Windows system due to the determinism, we took a look at your code and you don't have a code optimization problem.
Tell us if you need any other help.
Thiago Matos
Engenharia de Aplicações
National Instruments Brasil
(2,301 Views)
