Showing results forĀ
Search instead forĀ
Did you mean:Ā
Operations inside FPGA VI
Hi! Thank you for your response again! šŸ˜„ I'm just new to LabVIEW. What is the attached function called? šŸ™‚
Message 11 of 13
(456 Views)
That is the Max & Min function in the Comparison palette. In case you haven't come across VI Snippets before, the images I've been posting are actually drag & drop compatible with LabVIEW. Just drag the image onto a block diagram in LabVIEW and it should drop the code right in. I was using LabVIEW 2011, so the snippet will only drag into 2011 or later.
Message 12 of 13
(435 Views)
Yay it worked! šŸ˜„ THANK YOU VERY MUCH! šŸ˜„
Message 13 of 13
(421 Views)
