Opening a VI from another VI.
I'm currently writing a program which shares data between 2 VI's.  I need a button on one of them which opens the other is there a way that this can be done???
Matt.
Message 1 of 12
(4,162 Views)
Hi Matt,
Have you tried to create a sub-vi? That will work, if you have 1 main VI, that will need to call some other functions that are implemented in other VIs.
Is that you case?
TN
Currently using LV 8.5
logo
Message 2 of 12
(4,158 Views)
Ok I will give that a try have you got any examples I could have a look at?
Matt
Message 3 of 12
(4,153 Views)
Hi, I don't really know what you want, but you can place SubVI into MainVI and let work them parallely. If you only want to show the Front Panel of the SubVI, than you can use the VI Server to do it. It would be the common statical call.
If you want to make something like a menue and START your SubVI dynamically, than take a look on this example:
http://labviewportal.eu/en/front-panel/83-interactive-menue
Message 4 of 12
(4,144 Views)
Have a look at what i attatched. Hope it help. 😃
TN
logo
Message 5 of 12
(4,140 Views)
Sorry but I'm using Labview 8 not 8.5 do you have those programs in an older format??
Matt.
Message 6 of 12
(4,130 Views)
Sure, here it goes.
TN
logo
Message 7 of 12
(4,126 Views)
Forgot to attatch..
TN
logo
Message 8 of 12
(4,121 Views)
Thanks for the help.
Matt.
Message 9 of 12
(4,116 Views)
Accepted by topic author gilgad2000
Did that solve your problem?
If yes, don't forget to mark the solution and to give kudos! 😛
TN
logo
Message 10 of 12
(4,111 Views)
