07-15-2009 06:14 AM
I'm currently writing a program which shares data between 2 VI's. I need a button on one of them which opens the other is there a way that this can be done???
Matt.
07-15-2009 06:20 AM
Hi Matt,
Have you tried to create a sub-vi? That will work, if you have 1 main VI, that will need to call some other functions that are implemented in other VIs.
Is that you case?
07-15-2009 06:31 AM
Ok I will give that a try have you got any examples I could have a look at?
Matt
07-15-2009 06:38 AM
Hi, I don't really know what you want, but you can place SubVI into MainVI and let work them parallely. If you only want to show the Front Panel of the SubVI, than you can use the VI Server to do it. It would be the common statical call.
If you want to make something like a menue and START your SubVI dynamically, than take a look on this example:
07-15-2009 06:41 AM
Have a look at what i attatched. Hope it help. 😃
07-15-2009 07:16 AM
Sorry but I'm using Labview 8 not 8.5 do you have those programs in an older format??
Matt.
07-15-2009 07:24 AM
07-15-2009 07:25 AM
07-15-2009 07:25 AM
Thanks for the help.
Matt.
07-15-2009 07:28 AM
Did that solve your problem?
If yes, don't forget to mark the solution and to give kudos! 😛
