If you encounter access issues, please contact services@ni.com and include the learner’s name, email, service ID or EA number, and the list of required courses.
Opening LabVIEW project modifies VI
It appears that the problem continues with the new .vi.
My best guess is that something about the (cast) To More Specific Class is causing this issue for me:
Message 21 of 23
(1,541 Views)
I agree that this is an issue with working with SCC like git.  We were wondering how to get around this as well. We are using bitbucket with Gitkraken as the interface but having the .lvproj file change each time you open it even without modifications is annoying. Thankfully you can just discard changes.
Message 22 of 23
(1,458 Views)
Have you actually compared with what's in the repo to see what's changed?  I've found often that dependencies will change, especially if you are mixing VIs from different versions.  Or somtimes there are NO changes - LabVIEW just felt like it needed to change something, but it's identical except for the mod date.
Bill
CLD
(Mid-Level minion.)
Message 23 of 23
(1,441 Views)
