Showing results forĀ
Search instead forĀ
Did you mean:Ā
Opening .CDF files
I am trying to open some data processed with Matlab which are stored in a CDF file. Is there a way for opening this files in Labview or Diadem? I spent some time in the forum but could not find any solution; it is estrange because it looks a pretty common factor for the people who work exclusively in Matlab. Many thanks in advance. Best wishes.
(4,475 Views)
Hi Franitin,
In LabVIEW a CDF (component definition file) stores the real-time application, version information corresponding to your LabVIEW Real-Time executable, and any dependency information specified.
Are you referring to the above CDF or to the Common Data Format (CDF)?
Best regards
Menelaos.K
(4,437 Views)
Hello, Menelaos,
First of all, many thanks for your reply. Regarding to your question, I am referring to the CDF files created by Matlab. Despite that they are very common, I didn't find any standard method for opening them, neither in LabVIEW or Diadem. Let me know if need further clarifications. Many thanks in advance. Best wishes.
http://www.mathworks.co.uk/help/matlab/import_export/importing-common-data-file-format-cdf-files.htm...
(4,414 Views)
Hi, there.. Apologises for publishing again, but... can anybody help, please? Many thanks in advance. Regards.
(4,390 Views)
Hi Franitin,
Unfortunately National Instruments software does not support the CDF format you have mentioned earlier.
I am really sorry for this inconvenience.
Best regards
Menelaos.K
(4,340 Views)
