‎02-13-2015 06:09 AM
I want to open certain vi with using Windows batch file and to use specific version of Labview development system. I tried
"C:\Program Files (x86)\National Instruments\LabVIEW 2012\LabVIEW.exe" "path_to_vi"
"C:\Program Files\National Instruments\LabVIEW 2012\LabVIEW.exe" "path_to_vi"
to use 32-bit and 64-bit development systems respectively. However Labview opens file with version which was last used before. Are there any ways to force it use specified version?
‎02-13-2015 06:48 AM
I have a VI that can open VIs in different versions of LabVIEW and it works as you have described by opening the appropriate LabVIEW.exe with the path to the VI as the only argument. I'm not sure why this wouldn't also work for opening in the 32-bit or 64-bit version of LabVIEW.
‎02-13-2015 06:56 AM
What VI are you talking about? Is it in vi.lib or?
‎02-13-2015 06:59 AM
No, it's a VI I wrote so that when I open any VI from Windows Explorer it will open it in correct version of LabVIEW according to it's source version (rather than the latest/last version of LabVIEW I opened). All it does to launch the right version of LabVIEW is to call System Exec with the path to the correct version of the LabVIEW.exe and the path to the VI - which is essentially the same as what your batch file is doing.
‎02-13-2015 07:06 AM
Well it seems to be working for me now too, maybe that was Friday the 13th ![]()
