Open or read file
Dear friends!
Please, how can I read the attached compressed file (test.rst) with LabVIEW 8.6.  In the same VI, can I convert it into a real txt file with the results presented in rows and columns? Please, any idea? I need help!
In fact, the attached file (test.rst) is the result (output file - named restart plot file) of the RELAP5 code (Thermal Hydraulic Code). I would use this file (test.rst) to develop a visual simulation of the temperatures calculated in LabVIEW using RGB. I'm sending the original compressed file (test.rst). Do you think the plot restart file is binary? Would read it in Labview to develop my application?
Thanks!!!
(2,608 Views)
Accepted by Prof._Arne_Saknussemm
Duplicate Post.
You are already being helped there.  Asking the same question in a new thread is not going to change the answers.
(2,592 Views)
