Open front panel using reference
Hi!
I want to make the front panel of a subVI visible when pressing a button in mainVI..
I also want the subVI to start at the same time as mainVI.
Can anyone help?
I've attached some files to illustrate the problem. Its not working, but i think you get the point.
Message 1 of 9
(4,900 Views)
Hi MrNorway
try it like i show in the attached picture. I think you should insert a Wait in your subvi loop.
A better way to transfer your data from one to the other vi is to use a Queue.
Mike
Message 2 of 9
(4,885 Views)
Thanks Mike 🙂
But how do I use a Queue?
Message 3 of 9
(4,872 Views)
Hi MrNorway
there are good examples in the NI Example Finder. Search for "Queues".
Mike
Message 4 of 9
(4,853 Views)
Hi again!
I'm now using the method as Mike described...
But i want to make some changes.. I stll want both VI's to start at the same time, and I still want the subVI to pop up when I push a button..
But when both VI's are on screen, I want to be able to work on both VI's.. Now I can only make changes on the subVI because the property node FP.open always is true and will always be in front..
Anyone got some ideas on modifications i can make?
Bjornar
Message 5 of 9
(4,817 Views)
Hi Bjornar
here is a little example for you how to show and hide the parallel running vi.
Mike
Message 6 of 9
(4,798 Views)
Hi Bjornar,
i made an example for you with your specific problem. see the attachment. The transfer of your double value is now realized with queue.
Mike
Message 7 of 9
(4,783 Views)
Thanks again Mike!
Think I need some time to study the Queue example, but the "openclose.vi" works perfect for my prog.
I use global variables to transfer data between the VI's..Will I get a better transfer with Queue?
Message 8 of 9
(4,767 Views)
Hi Bjornar,
with a Queue it is possible to tranfer more than only one value. Furthermore every inserted value will be stored until you dequeue it. So you can´t lose values (presumed that the queue size is big enough). With a global variable it could be happen that you change the value two times within a short time but the receiver loop get only one change.
Hope it helps.
Mike
Message 9 of 9
(4,738 Views)
