Open excel file with button
Hello everyone,
Does anyone know if there is a way to open an excel file by pressing a button? I mean, in my VI I have a button, and if I press it, it should open the excel file.
(1,581 Views)
Research the command line interface node and the Excel command line options.
Use the command line interface node to launch Excel with the intended file on pressing the button.
This is just one more simple option.
André (CLA, CLED)
(1,533 Views)
Accepted by Mocte117
Alternatively you can try the VI described here:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019YKHSA2&l=en-US
This will actually open any document with its default application.
Attached is a small example.
Raphaël.
(1,530 Views)
