Open and select specific values in a file
Thanks I found the VIs.
I tested it :
I don't understand the values that I'm getting.
Should I wire the 2 colums containing the data somewhere ?
Like if I enter my 2 dates, how can I get the data (column 1 and 2) between those 2 dates?
Message 11 of 15
(901 Views)
@GerdW wrote:
Hi Bill,
@billko wrote:
Does this account for daylight saving (if applicable)?
When you want to avoid any DaylightSaving hassles you should store timestamps as UTC data (also when converting to string).
I guess the OP didn't care about that when creating the data text files…
That is exactly what I do.  Store timestamps as UTC; save any local formatting for when you extract the data.
Bill
CLD
(Mid-Level minion.)
Message 12 of 15
(896 Views)
Accepted by topic author Naxmouk
Hi Naxmouk,
Using those Threshold functions you get a row number in the corresponding timestamp array.
When you want to read data from certain columns of the 2D array then you need to "wire the data somewhere"!
So you want to get a subarray from your large 2D numeric array?
Hmm, maybe using the ArraySubset function might work - what do you think?
(How much basic LabVIEW training did you do before?)
Message 13 of 15
(889 Views)
Hello GerdW,
Here is my vi !
I wired the data to an ArraySubset, and it works !!
When I put my dates, I get the data between them !
I just know how the structures work and some basic VI's.
I use LabVIEW for my project where I need to do a UI, the data is coming from an Arduino Uno.
I need to acquire the data, the user has to enter the 2 dates and he get a graph showing the evolution of the data over the period he chose.
Thank you for your patience and for your great help !
Message 14 of 15
(880 Views)
Hi Naxmouk,
maybe you should also use the "Start" row when selecting data from your numeric array…
Message 15 of 15
(878 Views)
