Open Multiple .txt Files based on date
I am attempting to build a VI that opens the last 5 production days of data in order to create a "real time" history graph that compares each day.
Production days are Monday 7 am through Saturday 7 am. Shifts are 1= 7-3, 2= 3-11, and 3=11-7.
I already built a VI that saves a shifts worth of OEE/Production values into a .txt file with a date and what shift it was. Example: dd/mm/yyyy_shift#.txt  (I am open to changing that format).
I would like this VI to open all of the files for the previous 5 production days. I am having issues such as weekends or days when no production was planned (no file exists for that day).
Thank you,
(4,105 Views)
I put this together in just a couple hours so it is a little messy. But it's the main idea for the data saving VI. From here I would like the Data Open VI to take the date here I changed it to %j for testing but %d%m%Y is what that normally is. Again thanks for looking into this. Data Save.png
(4,086 Views)
Hi engineer,
What kind of issues?
When you know it is a weekend you only need to choose the next day. And you need to handle errors if the FileOpen function outputs them…
Other option:
Use ListFolder to get a list of all files fitting to your filename convention. Then parse the filenames and choose those ones fitting your "5 last days" requirement…
I recommend not to put slashes in filenames. I also recommend to format the date like YYYYMMDD for easier sorting of the files…
(4,080 Views)
Accepted by AUengineer
Hi Cory,
Once you have your list of files, you want the 5 most recent days. What I would do, is keep an array of the most recent days, and once you try to add the 6th one, stop looking through files. This assumes your array is sorted. I use a filename format like "YYYYMMDD_Filename.txt" most of the time, so that windows can easily organize by date. Here is an example to get you going:
(4,068 Views)
Hey Gregoryj,
Thank you for start on the file system. I do not want to manually input the file names of the most recent days. What would be a way to implement an array of saved files? I tried making that in the Data Save VI, but again I come across the issue of defining the previous 5 production days and whether or not all shifts were producing.
Thank you,
Cory
(4,012 Views)
Look for the List Folder function.
(4,009 Views)
