09-18-2017 12:53 PM
I want to open an Access DB from LabVIEW. I don't want to open a connection, I just want a button on the front panel that opens a specific Access DB file. I have a program that is reporting out information from this database, but I want to be able to open the database, make a change or updates, and then close the database. Update the form and poof, everything is up to date. I don't want to manipulate data from my program.
There has to be a way to open a database, right? I have searched on this subject, and I can not find a method that has worked for me to open a database.
Any help is greatly appreciated!
Dave
Solved! Go to Solution.
09-18-2017
01:01 PM
- last edited on
04-26-2025
10:31 PM
by
Content Cleaner
09-18-2017 01:16 PM
But that is used to open a connection to Access. Not what I want to be doing. I want to click on the button and open a specific database. Like if I went into explorer and double clicked on the file and it opened in Access.
Dave
09-18-2017
02:02 PM
- last edited on
04-26-2025
10:31 PM
by
Content Cleaner
I'm not sure if I really understand what you try to achieve. Do you want MS Access to start and then open the access db file? Or another Executable? In that case have a look at the System Exec VI
Regards, Jens
09-18-2017 02:45 PM - edited 09-18-2017 02:46 PM
09-18-2017 03:40 PM
Your description is correct Jens. I have looked at the System Exec VI and I haven't gotten it to run or open the file I want it to open. I thought that should work too. Perhaps I need to just mess with it some more.
Dave
09-19-2017 06:32 AM
09-19-2017 11:19 AM
Thank you for the example. I have been trying to figure this out, but I didn't think it would be this simple. I shall give this a go. Thanks!!
09-19-2017 11:23 AM
Thanks! It was just too simple! I of course was overthinking it and trying too many different things. That space in between is critical as well!
Thanks again!
Dave
