Open LabVIEW 2015 vi on LabVIEW 2013
I am working with some electronics equipments and, to control them, the manufacturer sent me LabVIEW vis in 2015 LabVIEW version whereas I have only LabVIEW 2013.
Do you know if there is a way to open these vis? Because when I try I have an error message about the compatibility (LabVIEW2013/2015).
Thank you in advance.
Mathieu Gauquelin
(2,365 Views)
Accepted by topic author Mathieu33800
Asked moderator to move to conversion board.
Post the code, and ask the moderator to mode this thread to the conversion board.
Or, ask the manufacturer to save to previous version.
Or install LV15 of course. Then use 15, or use 15 to save to previous.
LV is not forward compatible, you can't open newer code in earlier versions.
(2,349 Views)
