One graph with multiple layouts
Hi, Just a quick question. I have just finished developing one of my programs and was wondering if any new how to do the following.
1.I have have multiple graphs on the front panel, is it possible to display one graph at once and rotate between graphs.
2. another way is it possible to press a button to pop-up, one graph at a time.That i have chosen to select, which could be separate screens or the same screen.
Any examples would be greatly appreciated
(3,025 Views)
You might be able to use a tab control for the multiple graphs.
(3,025 Views)
Hi Mike, thanks for that should work a treat.
Thanks Stu
(3,025 Views)
stu22,
Also try this example. It allows you to show and hide lots of plots at once without using multiple graphs. It should at least get you started.
Randy Hoskin
http://www.ni.com/ask
(3,025 Views)
