Once true, make LED stay green
I have an LED that lights green when a timer and set time are equal/greater than.  How can I force the LED to stay active?  Such as if the timer gets reset...  The LED needs to still show active.
Message 1 of 13
(4,654 Views)
You can use Boolean's Property Node > Value to set the boolean to high.
Andy Chang
Message 2 of 13
(4,649 Views)
Use a feedback node. Wire the OR of current value and last value to the LED and back into the feedback node.
Message 3 of 13
(4,647 Views)
My only problem with that is that it's all constantly being looped.  Won't it just keep checking?  If the timer gets reset it won't match the set time then the boolean will just reset.  Attached is the code for what I have.
Message 4 of 13
(4,631 Views)
Or search the forums for a Boolean Latch. Such as the one in this thread.
Richard
Message 5 of 13
(4,626 Views)
In case you don't know the feedback node, here's the concept of latching using a shift register.
Message 6 of 13
(4,620 Views)
I guess I should have thought of that... Smiley Very Happy
Message Edited by NIquist on 03-19-2010 04:15 PM
Message 7 of 13
(4,607 Views)
Message 8 of 13
(4,593 Views)
hello everyone,
i hope that i am posting under the right header.
I did a program for led using case structure and while loop. but the problem is that the led is blinking. i
dont want it to blink. i want the pin to stay high then when i press the boolean, it shall be off.
the led pin is on my breadboard.
can any1 help
 the first snapshot i use a simple case structure
Message 9 of 13
(3,902 Views)
@Zahkay wrote:
hello everyone,
can any1 help
Start a new thread.  And post the actual code.  The pictures you gave is not enough information to diagnose the issue.
GCentral
Message 10 of 13
(3,889 Views)
