On power up MXS starts up and uses abnormal amounts of CPU and Drive resources?
On power up MXS starts up and uses abnormal amounts of CPU and Drive resources? The resources used interfere with the LabVIEW application running properly after it is loaded and executed. This problem never subsides. There are two identical systems running the same applications / version 2016 Development LabVIEW and only one windows 2010 computer exhibits this problem. The second has almost zero MXS resources being used. I have tried removing all PCI and PCIE hardware with no effect. I also tried to update the computers BIOS and load the latest LV patches. Thoughts?
(2,793 Views)
Hello AIBes:
Can you please bring more information about the application and hardware/software configuration?
Also, the MXS would be the package of drivers?
(2,748 Views)
I followed 4GA9ToQA knowledge data base to – How to Restore the NI MAX Database File - instructions. After following the procedure and restoring the damaged data base the issue has gone away.
(2,733 Views)
