03-02-2018 12:53 PM
Is any body previously work on M^2 Measurement of Laser Beam?
If yes, then Please help me out need Little guidance.
I am trying to make a VI which determine Laser beam quality and measurement using NI Vision.
I have a average command on Vision. But, this i am not sure How should I processed?
Any help will be appreciate.
03-05-2018 09:58 AM
In order to provide any suggestions, can you elaborate a little more on what you are trying to measure? What constitutes as a good quality beam? Is this light intensity? Shape of beam? Size of beam? Etc?
Once you determine what makes a good beam we can then determine what processes you can take to measure those conditions.
03-05-2018 10:03 AM
Basically, the Laser Beam Determination based on,
Light Intensity
Shape of the Beam
Background Correction
Centroid position X Y
Defining the cordinate system to Beam
Recording the beam location and calculate the change in the location
Size of Beam
Beam Quality in %
Parth
03-06-2018 08:01 AM
Are you using Vision Assistant by chance? There is a good tutorial on all the different functions that can be utilized with NI's vision software linked below.
Even if you're not using Vision Assistant (which I would recommend doing) you can also create this same functionality with IMAQ VI's in a LabVIEW project as well.
NI Vision Assistant Tutorial
03-06-2018 08:06 AM
ok. I used Vision previously for other kind of diagnosis.
Do you have any idea about how can i find the intensity profile of the laser beam using IMAQ?
Parth
03-06-2018 08:15 AM
I've never personally done it, so I can't really say. But this form post talks about a few approaches to get the intensity profile. I hope that's helpful!
https://forums.ni.com/t5/Machine-Vision/To-Extract-Intensity-Profile-from-Image/td-p/138356
