Omega USB-DIO96 Read Byte
Hi
I have a small problem I hope someone can help me with. I am using the Omega USB-DIO 96 and writing to the ouput ports successfully using labview.
Now I have come to reading from the input ports using the same labview 'call library function node' however all I ever get on the returned data is ' 0'.
The API return code is ' 0' indicating a successful read but the displayed data is incorrect.(I can read the correct data with the supplied SeaIO VC test function software)
I have checked all the obvious things (ports configured as Inputs, correct card number, correct port and addressing mode) but cannot see where the problem lies and am now stumped.
It would be much appreciated if someone could please take a minute to look at the attached vi and see if they can spot where the fault lies.
IanR
Message 1 of 1
(2,477 Views)
