Ok button on one/two button messages is wrong font type
Hi guys!
I have installed LV2010 SP1 and now I have some problems with the One/two button message. Maybe for three button also. If I haven't set a constant to the button message, this happens:Wrong OK button.png
The OK button looks nothing like OK. If I put on a constant and write "OK" in it, the OK button is normal. I usualle don't bother putting on the constant since the standard text is "OK". This problem effects also my old programs wich I've never had any problems with.It affects other computers with the 2010SP1 Run-time when I install my new applications.
Anyone knows what the problem could be?
Even
_________________________________
Certified LabVIEW Associate Developer
Automated Test Developer
Topro AS
Norway
(3,298 Views)
I wonder if this is a bug in the localization files for SP1.
I am assuming you're using the Norwegian version of the product?
I'd report this to NI:   http://ni.com/ask
Hilsen, J
http://www.medicollector.com
(3,265 Views)
Hi:)
I use the english version of LV. But my Win7 is in Norwegian. Thanks for the link:) I'll ask there
Even
Topro AS
Norway
(3,230 Views)
Accepted by topic author EvenDeejay
Hi
Have you tried to do a repair of LabVIEW through add/remove programs in windows?
To check if its a language compability problem you can try to change to english format in Region and Language in control panel and see if the error is still there. I have testet this function at our office with a Norwegian operating system and was not able to reproduce it.
Regards
Espen
AE NI Norway
(3,189 Views)
I tried repairing the SP1 and it worked.
When I installed I downloaded the SP1.
When I repaired it I used the DVD's that came by post.
Don't know what caused this error, but now it's anyways fixed.
Even
Topro AS
Norway
(3,166 Views)
