03-18-2011 02:31 AM
Hi guys!
I have installed LV2010 SP1 and now I have some problems with the One/two button message. Maybe for three button also. If I haven't set a constant to the button message, this happens:
The OK button looks nothing like OK. If I put on a constant and write "OK" in it, the OK button is normal. I usualle don't bother putting on the constant since the standard text is "OK". This problem effects also my old programs wich I've never had any problems with.It affects other computers with the 2010SP1 Run-time when I install my new applications.
Anyone knows what the problem could be?
03-18-2011 12:57 PM - edited 03-18-2011 12:58 PM
I wonder if this is a bug in the localization files for SP1.
I am assuming you're using the Norwegian version of the product?
I'd report this to NI: http://ni.com/ask
Hilsen, J
03-21-2011 01:27 AM
Hi:)
I use the english version of LV. But my Win7 is in Norwegian. Thanks for the link:) I'll ask there
04-11-2011 08:22 AM
Hi
Have you tried to do a repair of LabVIEW through add/remove programs in windows?
To check if its a language compability problem you can try to change to english format in Region and Language in control panel and see if the error is still there. I have testet this function at our office with a Norwegian operating system and was not able to reproduce it.
Espen
AE NI Norway
05-18-2011 06:28 AM
I tried repairing the SP1 and it worked.
When I installed I downloaded the SP1.
When I repaired it I used the DVD's that came by post.
Don't know what caused this error, but now it's anyways fixed.
