Offline Activation Code Issues
I have a LabVIEW Professional Development System Debug Deploy license on a computer disconnected from the internet, running LabVIEW 2024 Q1 (32-bit). I now need the 64-bit version of the software, but only the 2025 Q1 version is available for offline download. I loaded the 2025 Q1 version, but when generating the offline activation code here, the versions listed for "LabVIEW Professional Development System Debug Deploy" only go up to 2024 Q1. So I can't generate an authorization code for my 2025 Q1 offline installation, and I can't download the offline installation of 2024 Q1 which I would be able to activate.
Does anyone know how I could access an offline installation of 2024 Q1 (64-bit), or do you know if there is another way to successfully activate the offline installation of 2025 Q1 (64-bit)? Much appreciated.
(1,919 Views)
We're having a lot of activation problems the past few days. There might be issues complicating your task...
Simply starting the software is what I usually do. This should give you a dialog with activation options. This normally works, but (because of the issues) I gave up on that and switched to the license manager.
The license manager has several ways to activate a license.
Normally, activation with a license code (in the product's dialog or with the license manager's dialog) is the easiest.
We tried to activate by license code, but because of the problems (at NI I assume) it fails.
However, we do get an email with activation codes (also when activating through the product, in hindsight) . These activation codes (there's a concatenated list at the bottom of the email) can be copy-pasted into the activate by activation codes option. This works.
Hope it helps...
(1,854 Views)
