Office Color Table
I have a graph with a variable number of plots. Now I want to create a word report. So I save the graph via the method node as a picture on my harddisk and start with the report. In the report I add the picture and a table with descriptions to each plot. In the next step I change the color of the font in the table to the same color the plots have. This i do with a for loop, which switches through the plots in the graph and saves the plot color to an array. But when a use this array for coloring the table elements in the report, not all of them have the same color like the plots have. How I can solve this problem?
MZ
(4,062 Views)
Hi Markus,
Could you please post a small example to help us help you?
Are some of the colors correct?
Ben
(4,046 Views)
Hello Ben,
thanks for your answer. I have build a quick example. As you can see, some of the colors do not agree.
Markus
(4,037 Views)
HI Markus,
My hands are tied because I do not have the office toolkit installed at home.
I seem to rember that the office colors (may be wrong!) are not RGB but rather BGR. This would make green OK but red and blue would be swapped. Could you post inages of the LV graph and the image of the report?
Ben
(4,023 Views)
Hi Ben,
with this post I send a pdf file with the result. As you can see, the color of Plot 3, Plot 4, Plot 5 and Plot 6 is wrong.
MArkus
(4,006 Views)
can not open pdf.
please post jpg or png.
Ben
(3,996 Views)
Hello Ben,
here is the jpg.
Markus
(3,991 Views)
