‎12-15-2008 08:20 AM
I am having problems with the "Timed Loop". Even on a simple vi I cannot get the timings to be consistant.
I opened up a new vi and put a time loop with a Read From Feild point connected to a time stamp. The loop is set to 5000ms (5sec). The time stamp however sometimes does not change or it will, but not in intervels of 5 seconds.
Chaz
‎12-15-2008 08:25 AM
Hi Chaz,
on which OS or platform is your vi running? Is it real time?
Mike
‎12-15-2008 08:30 AM
‎12-15-2008 08:58 AM
Hi Chaz,
where is the vi running, on your Windows System or on your cFP? You need a real time system to get real time values.
Mike
‎12-15-2008 09:11 AM
Hi Mike,
Thanks for quick responce. It is running on the Windows system. I am fairly new to this... 😞
If it helps ~ Currently got the cFP wired via ethernet to the pc, using static ip.
