Odd Startup behaviour and cannot access tools->options menu
As of this morning my installation of LV8 will not display the normal startup dialog box (allowing you to open existing VIs or open a new one), but simply opens a new VI immediately.  If I close this new NI then again instead of returning to the start up dialog it opens a second new (blank) VI.    Furthermore I cannot open the Tools->option menu from within a VI front panel.
I've tried repairing the LV installation and when this didn't work I went for a full remove and reinstall - still no joy!
I've also check that this is not user specific, so that when I log in as a different user on the same PC I get the same behaviour
Help - please !!Smiley Sad
(4,715 Views)
Accepted by AMHurrell
Hi AMHurrel,
This sounds rather strange.
Did you change anything on your setup?
When you say you did a full remove and reinstall, how?
These are the steps I would follow:
The following procedure will remove the National Instrument Software:
1.     Turn off the computer and physically remove or unplug all NI hardware that you have installed on your system.
    This includes anything that is PCI-, ISA-, USB-, 1394-, or ethernet-based.
2.     Turn the computer on and go through Add/Remove Programs (START » SETTINGS » CONTROL PANEL » Add/Remove Programs)
    and remove everything NI-related. Generally, if you can remember, it is best to uninstall things in
    the reverse order in which they were installed. For example, if you installed LabVIEW, then NI-DAQ, and then the
    Internet Developers Toolkit for LabVIEW, you should uninstall the Internet Developers Toolkit first,
    then NI-DAQ, and then LabVIEW last.
3.     After everything has been removed (do not be concerned at this point if an item still shows up in the
    Add/Remove Programs list after you have removed it), close all programs and restart your computer.
4.    Go to START button of your operating system, choose RUN and type "regedit". This will open the Registry
    Editor window. Go to the Registry Menu and choose Export Registry File. Select "All" for the export range,
    and select a file name. This creates a backup of the Registry in case a mistake is made when deleting the keys.
5.     Remove the following registry components from the Windows Registry:
    HKEY_CURRENT_USER\Software\National Instruments Delete the entire tree!
    HKEY_LOCAL_MACHINE\Software\National Instruments Delete the entire tree!
    HKEY_LOCAL_MACHINE\System\CurrentControlSet\Enum\PCI\ or \ISA and delete registry entries containing any
    keys with 1093 in them.
    Do not worry if any of these trees are not listed. Continue with the remainder of the process .
    Note: You may need to modify security policies. In Windows 2000/98/95/NT, go to [regedt32] then
    Security>>Permissions. In Windows XP you can modify security options using Edit>>Permissions in the
    Registry Editor (regedit).
6.     Close regedit.
7.     Make sure that you do not have any of your own VIs or other files saved in the "C:\VXIpnp",
    "C:\Program Files\National Instruments", or "C:\WINDOWS\nidaq" folders. If you do, copy them to a
    different location. If you are concerned about keeping old virtual channels and your SCXI setup intact,
    then backup the "C:\WINDOWS\niconfig.daq" file, too. Delete all folders and files mentioned above.
    Note: If you have Windows NT/2000, replace "C:\Windows" with "C:\WINNT" in the paths listed above.
8.     Save the attached file msiBlast.zip to your desktop.
    a) Extract the file msiBlast.exe from the zip archive.
    b) Double click on the downloaded msiBlast.exe file to run the executable.
c) Choose the Show NI Installers Only selection.
d) Using (Ctrl+Left Mouse Click) select all National Instruments Software that appears in MSIBlast.
e) Press the Uninstall button. This will uninstall all of the National Instruments MSI Registry entries.
f) Optional:
The Repair option will open the National instruments Installer Program and run the repair option within the installer.
Maintenance Mode will open the Installer Program and allow the user to modify the installation. To open the installer do not enter anything in the Command Line Arg? Dialog box.
9.     Reboot your computer.
10.     You should be ready to install your software. For the cleanest possible install, first install all of your
    application development software, such as LabVIEW, Measurement Studio, etc. Do a custom install, so that you can
    install just the application WITHOUT ANY DRIVERS. Reboot your PC when requested after each install.
    Even if the installer does not tell you to reboot, it would probably be a good idea to do so anyway.
    Now install your driver software and follow the associated user manuals. Some older non Plug-n-Play hardware
    must be installed before the driver. Download the latest versions of the drivers that support your hardware
    from our Drivers and Updates software library (link below), and install them one-by-one, rebooting after each
    install.
11.     Finally, shut down and re-install your hardware. When you boot back up, it should be detected in MAX.
NI Drivers Link :  -  http://www.ni.com/softlib.nsf
**Attached is msiBlast.
***Do you get an error messages?
Let me know what you think,
Kind Regards
Kind Regards
James Hillman
Applications Engineer 2008 to 2009 National Instruments UK & Ireland
Loughborough University UK - 2006 to 2011
Remember Kudos those who help! 😉
(4,701 Views)
When you did the full remove did you delete the LabVIEW directory? If not, try deleting the LabVIEW.ini file and see what that does.
(4,684 Views)
Thanks Hillman - that's cracked it !!Smiley Happy
Many thanks for you assistance
(4,675 Views)
Hi James,
I follow your instructions for install the labview.  But I can not uninstall the follow packages through MSIBlast
NI PXI Platform Framework 1.1.3
NI PXI Platform Services 2.5.1
NI-DIM 1.9.0f0
NI-MDBG 1.9.0f0
NI-MRU 2.10.1f0
NI_MXDF 1.10f0
NI-0RB 1.9.3f0
There are the error messages pops can’t uninstall.  Is there another way to remove everything before I install the Labview again.
Kim
(4,333 Views)
