Obtaining zero values to use for data calculation
Hey guys, I'm looking to "capture" a zero reading before I start my data measurement. I have 4 analog channels that are running continuously through a producer/consumer architecture. I want to push the "start" button and hold the most recent value for these 4 channels in order to compute some conditions later on in my code. Is there a way to do this without using local variables?
Message 1 of 13
(3,632 Views)
Hi glskinner,
usually you use ShiftRegisters to "hold" values. No need for locals...
Message 2 of 13
(3,628 Views)
Hi Gerd, How do I hold these values if I'm taking continuous data? I want to store them once an event happens.
Message 3 of 13
(3,624 Views)
Hi glskinner,
the standard pseudo-code would look like this:
IF event THEN
  store new value in shift register
ELSE
  keep old value in shift register
ENDIF
 A simple Select function can help here...
Message 4 of 13
(3,620 Views)
so, something...(big something) like this?
Message 5 of 13
(3,613 Views)
Hi glskinner,
no, you did not follow my pseudo code. You always keep the old value in the shift register...
Message 6 of 13
(3,610 Views)
Old values are coming from the right side of the shift register..correct? And the most recent are on the left?
Message 7 of 13
(3,593 Views)
Accepted by glskinner
Hi glskinner,
when you're unsure about usage of shift register you should take the online courses available at NI.com!
See this:
Message 8 of 13
(3,587 Views)
My data is coming from a continuous 1d array. Could I index it into a for loop and use the method you described above? I see that the true selector is a constant/control. I want to read my analog channel (indicator)...and get the most current value passed from the array.
Message 9 of 13
(3,574 Views)
Hi glskinner,
what is a "continuous array"?
What means "pass a value from an array"?
Yes, you can index values from an array using IndexArray. (Did I mention online training courses before?)
Yes, you can "read your analog channel". What's the problem here?
Message 10 of 13
(3,570 Views)
