Object method VI memory
    I have some questions about method VI of an object:
    1. When the object method VI is loaded and unloaded from memory? For regular subvi, you can configure it as load with caller, reload for each call and load and retain on first call. How about object method VI?
    2. If I have two objects of the same class on the diagram will two copies of the method be loaded or it depends on the reentrance of the VI property?
    Thanks for help!
    Tom
(3,201 Views)
Hello Tom,
I would encourage you to check out LabVIEW Object-Oriented Programming: The Decisions Behind the Design and LabVIEW Object-Oriented Programming FAQ to obtain more information on OOP methods.  I believe your questions can be answered herein.
Lynn
Senior Systems Engineer
(3,179 Views)
@Sarci1 wrote:
Hello Tom,
Lynn
Load with caller is covered in those?
I guess I have to read them again (for the tenth time).
Ben
(3,174 Views)
