Object is invalid in Get data to modify.vi
       When I am calling Getdata to modify.vi to get member variables and trying to set some values using SetModified data,I am getting an error "Error1 Object xxxx is invalid"in GetdatatoModify.vi.]
 I am accessing the referance of object as session type,the using variant to data conversion to convert back to referance of object.Please help me on the same and give me a solution.
(3,043 Views)
It sounds like you are referring to a VI you wrote, but I cannot discern the problem you are having.  Please post as simple a piece of hardware independent code which reproduces the problem, along with a very specific explanation of what's happening.  The more careful you are in writing and explaining the problem, the better I'll be able to understand it and try to help you.
Best Regards,
JLS
Best,
JLS
Sixclear
(3,014 Views)
This is a copy of this thread.
Please stop creating the same question over and over and read the responses that have already been given.
(3,004 Views)
