Object Oriented
Hello, everyone.
I am now programming for a teststand. The old program has 7 module and is programmed with the traditional programming method. Now I have programmed two module with the OOP and want to replace the old module with the new. The main program, which controls the 7 module, should also be changed.  Is there something that I should pay attention to?
(3,727 Views)
Hello alre,
You should read this white paper.
https://www.ni.com/en/support/documentation/supplemental/06/labview-object-oriented-programming--the...
Have you ever developed in LabVIEW OOP? Else training could be a good idea!
Good luck.
Sabri JATLAOUI - Certified LabVIEW Architect - Certified LabVIEW Developer
(3,706 Views)
I have learned the Labview OOP Kurs and developed two module with OOP, thanks for the LinksSmiley Happy
(3,695 Views)
Not really- treat class objects like a cluster with limitations on where the fields can be accessed and you won't go far wrong.
(3,688 Views)
I have finished to replace the old program with the new OOP module. It will then be tested on the teststand.
(3,576 Views)
