Hi Enrique,
Playing the devil's advocate is the role I generally play, but I'll let you take that part for the time being.
My customer is running test that take from 15 to 30 minutes to run. The dictate from above says "password protected screen-saver set for 10 minute time-outs".
This means the operators will have to "jiggle" the mouse regularly if they want to be able to monitor the test's progress.
Now add to this the fact that they are running the same app on 4 PC's, this works out to at least one jiggle every 2.5 minutes.
The operators of these systems were busy enough with the work involved in conducting the tests. If they get delayed in the "jiggling", they are going to have to stop and log-in again. Of cousre we can just say "well they
are just going to have to move faster" but operators "running laps" in a lab that is using Hydrogen Sulfide, anhydrous ammonia, phosgene, and cyclohexane all the same time is a safety hazard.
So this reduces to a decision between a security risk, and a safety hazard. The security risk for a restricted lab inside a secure complex is low.
The option to have the "jiggling" done automatically while tests are running is an option that allows the systems to comply with the dictates from above while maintaining a safe and productive laboratory. None of these systems will be left un-attended while tests are running so strangers walking in and deleting files or installing virus ridden software while the tests are running is a long shot.
I have not implemented the "auto-jiggler" into the application. I have given the customer the option to try this approach if they so choose. It is their call.
Thank you for the "sanity check". It is this type of thoughtful responses that make this e
xchange a valuable resource. ("As face answereth to face, and iron answereth to iron, so does a man trieth words", "There is wisdom in a multitude of counsellors" Proverbs)
Ben
