OPC automation active-x help
Hello, I need to modify some bits that Labview read from a PLC using a kepserver, however the program uses an active-x library that I haven't seen and I cannot find it, I was wondering if any of you have seen it before and point me to where I can search for information.
I'm using Labview 2015
Javier
(3,470 Views)
Hello Jrocha_16
What do you mean with "the program"? The vi?
(3,414 Views)
Hello CMurillo, first of all thanks for replaying, and yes, with "the program" I refer to the vi that I attach.
Best Regards,
J. Rocha
(3,409 Views)
Hello  Jrocha_16,
I'm not sure what do you mean. ActiveX  is "a Microsoft-created technology that enables different software applications to share information and functionality".
If you have Micrsosoft you are supposed to have ActiveX.
Can you clarify?
Best Regards,
César Murillo
(3,397 Views)
Hello CMurillo,
     Probably I have been using the wrong expression but it's for automation controls,
     That's what I'm referring to.
Best Regards,
J. Rocha
(3,394 Views)
