OPC-UA Method Call
Hi everybody out there....
Does anybody know if it is possible to call a method using an OPC-UA Client (DSC module). I have to do this, but I cannot see any methods in the browser tool although there are some implemented in the node class (server side).
Thermo
Message 1 of 9
(5,012 Views)
Hello Thermo,
it seems that this feature is not implemented at the moment.
best regards
Alexander
Message 2 of 9
(4,963 Views)
Hello guys,
do you have an idea is such a feature has been implemented now?
Message 3 of 9
(3,983 Views)
I have the same problem! Or does somebody know a work around to call OPC UA methods over LabVIEW?
Message 4 of 9
(3,571 Views)
Hello to all,
i used a workaround. I created a OPCua client and use the event subscribtion. In the  event structure the method will be placed.
http://zone.ni.com/reference/en-XX/help/376230B-01/opcuatool/using_opcua_clnt/
Hope this helps a little bit.
best regards
Alexander
Message 5 of 9
(3,565 Views)
@Duffy2007
Did I understand that right, that you first create an Event Subscription and then add the methode to the Monitored Event Nodes? The methode will create an event if it's executable?
And how you call the methode? With the Respond Acknowledgeable Condition VI?
regards,
Dominik
Message 6 of 9
(3,547 Views)
Hello DominikZ,
Yes you are right i created a dummy client for this and i used this architecture and placed the method in the event structure.
You have to change the subcription time. I set it too 2ms for checking the change.
best regards
Alexander
Message 7 of 9
(3,528 Views)
Thanks a lot.
But did you use the the Respond Acknowledgeable Condition or the Enable Condition to respond (call) the method?
And if you use the Respond Acknowledgeable Condition what do you have to send as a request method? Confirm or Acknowledge
Message 8 of 9
(3,508 Views)
Hello DominikZ.
sorry i did not used this functions, because i want an event based solution.
best regards
Alexander
Message 9 of 9
(3,498 Views)
