OPC Client Multiple Write?
Hi, how do I recreate this bloc shown in the attached pic. I have looked all over the web and looked into NI documetation butcant figure it out. I dont know how to create the request cluster wired to the budnle block as show in the pic. I get that cluster from OPC Multiple Write block when I right click and create constant, but I cant wire that bloc to the bundle. I end up getting error.
(1,583 Views)
This is because you don't get a cluster constant, rather an array of clusters. If your LV version is recent, you need to right click on the array constant and select Change to element. Then you can wire it to the bundle node.
Paolo
(1,567 Views)
