OMG Data Distribution Service (DDS) Implementations
I am trying to find a DDS implementation to run on a cRIO 9068. I have seen that RTI provides an implementation, but I was wondering if any others might work on a cRIO. For example, has anyone been able to get OpenDDS, OpenSplice, or InterCOM DDS to work on a cRIO? Feed back would be appreciated.
(3,665 Views)
Hi jameshand,
Were you able to try any other dds implementation on CRIO
Dj
Waiting For the inner calling 🙂
(3,477 Views)
Yes, I was successful in compiling and running OpenDDS on a 9039 CRIO.
Utilizing the compiler here: http://www.ni.com/download/labview-real-time-module-2017/6763/en/
I installed this compiler on a linux host running Ubuntu 18.04.2 LTS.
I then followed the instructions provided by OpenDDS meant for a raspberry pi just switching out the compiler with the one above.
The main thing that made it difficult was I had to point the OpenDDS Configure script toward a bash file that executed the compiler with all of the necessary include paths. (include paths can be found in NI's Getting Started with C Cpp Development Tools for NI Linux Real Time.pdf, but do not include the -c in the command).
Besides that the instructions that OpenDDS provides for the Raspberry pi should work.
Respectfully,
James Hand
(3,468 Views)
Thanks for letting me know. Glad that it worked
(3,460 Views)
I assume that your cRIO runs NI RT Linux.Have you tried it on any PXI Realtime controllers that runs Phar Lap ETS RTOS ?
Dj
(3,435 Views)
