OLE32.dll crash Labview
I am using LV 2009,
I am facing a problem for crashing my appication after running for 3-4 days, the error is crashing of OLE32.DLL.
I am using parallel while loops, queue, and database interaction(read/write).
The problem is faced on different PC and on code and as well as exe.
please refer to attached image.
(3,151 Views)
Hi Shrekt,
Did you ever find out what was causing this? It appears I am having the same problems (or at least similar symptoms: LV2009, crashing VI/EXE, after several hours, database interaction).
Victor
(3,013 Views)
