OLE DB connect timeout
I have an intermittant problem connecting to a server based MS Access database.
I am using LV 7.1, Windows XP. I configured a "Data Link" to connect to the database and am wondering about the "Connect Timeout" and the "Access Permissions" settings found in the avanced tab of the datalink properties.
I plan to set the access permisions to ReadWrite? 5 Seconds for the timeout? Does anyone have expeience with this?
Any input would be greatly appreciated.
Jim
(3,180 Views)
What kind of intermittant connection problem are you having?
I was unable to change the timeout settings in the Data Link file I created, what are the other settings you have in your file?  You might want to verify you are creating your UDL correctly.  Chapter 3 of the LabVIEW Database Connectivity Toolset User Manual provides instructions to configure a UDL.
Micaela N.
Micaela N
(3,160 Views)
I set the "Access Permisions" in the advanced tab of the data link to read write and the problem went away.
(3,150 Views)
Glad to hear your system is running properly.  Thanks for sharing your solution!
Micaela N
(3,147 Views)
