01-28-2016 02:22 AM
Vision OCR Training is unable to recognise the decimal point of an LED seven segment meter inspite of training the software. The software thinks the number before the decimal point and the decimal point is one number. Is there any way to tell the software that they are two separate characters?
01-28-2016 02:58 AM
I encountered similar problems. The problems stems from the fact that your numbers are tilted. The OCR tries to put a rectangular box around the character but due to the tilt of the numbers it means that the decimal dot is partly in the box of the "1" and it is recognised as one.
Try to train the "1" and the "1." separately as one chacter each and train the "1." with the string "1." ... it's a bit more work but should hopefully work
Best Regards
Mathis
01-28-2016 03:32 AM
Thanks for the input. I tried slightly rotating the image and it did recognise the decimal point. This worked fine when only "1." was selected. But it read "1." as one character when the entire line was selected 😕
01-28-2016 04:36 AM
The rotating won't help much as even if it doesn't look to you that the two rectangles are interfering anymore, you actually need a clear space between characters to be recognised as separate.
Rather than trying to force the OCR to recognise "1" and "." separately, try to train it to recognise "1" and "1.".
01-28-2016 10:31 PM
I did try that but the characters are too close to each other. Probably cant use OCR for this meter.
Thanks anyway
