Numbers bigger then 10 to a array of integers
Okay I want to do the following...
I have a number (bigger then 10). Assume I got the number 4327 now I want to change this number to a numeric array with the values [4,3,2,7] as fast as possible.
I only thought of one solutions (which is possible also the fastest), but I want to know if anyone has maybe a better idea.
My solution is just to cast that number to a string using the NumberToString VI, "4327", then split into a array of strings ["4","3","2","7"], and cast it back using the StringToNumber VI.
Anyone got a better faster idea?
Message 1 of 25
(4,341 Views)
If the range of input is not too huge the fastest way might be to precreate an array and index it
LabVIEW 2012
Message 2 of 25
(4,340 Views)
Let the UI thread help you?  (works for any base!)
"Should be" isn't "Is" -Jay
Message 3 of 25
(4,333 Views)
Why convert to strings and back?  Just use a bit of math:
Message 4 of 25
(4,326 Views)
But are those two methods the "fastest" ways?
LabVIEW 2012
Message 5 of 25
(4,323 Views)
This is faster than the previous two.
Message 6 of 25
(4,314 Views)
On my machine, at least, my approach is about 20ms faster (for 1 million 7-digit numbers).  Attached is the VI I used for benchmarking.
Message 7 of 25
(4,300 Views)
Accepted by topic author WG-
Absolutely not!
Although Nathand's solution could be expanded to work with any base as well. This may be a bit faster
the use of native recursion vs the buffer expansion should show in favor of the recusive technique up to a considerable number of digits.
Message 8 of 25
(4,298 Views)
@Jeff Bohrer wrote:
Absolutely not!
Nowhere close, unfortunately.  Here's the benchmarking VI updated with your code, which is 4-5x slower than both my approach and Matt W's.  The recursive implementation is a good idea but LabVIEW's recursion is not terribly efficient.  Each recursive copy requires allocating an entirely new copy of the VI.
EDIT: uploaded recursive subVI, needed as well.
Message 9 of 25
(4,293 Views)
I'd go with that, it is fast enough. 😄
However, make sure that the input is never negative. 😄
Message 10 of 25
(4,289 Views)
