Number to String Conversion
So the question is, what is rounding my numbers?  Or, more generally, what have I done wrong here?
The main program this sub.vi runs for needs these numbers as strings, and I think I have either picked the wrong number to string conversion .vi or missed a setting somewhere, becasue the program takes a perfectly good number like -0.340316 and rounds it to -0 (negative zero? that's right, negative zero).
Negativity of the zero aside, the number to decimal string .vi is rounding my numbers to integers.
(14,484 Views)
Accepted by LarsUlrich
The function is supposed to convert to an integer. Simply go to Help>Show Context Help and read the description. The function you want is called Number to Fractional String.
(14,480 Views)
Haha thanks, I had read the first sentence of the context help "Converts a number to a string of decimal digits at least width characters wide" and that just sounded like what I needed, the "decimal string" name is a little misleading to noobs like me.
(14,477 Views)
Yes.  It has always seemed misleading.  In this case it means decimal as opposed to hexadecimal, octal, or binary, rather than decimal where most people think of numbers that have a decimal point.
(14,468 Views)
