Number of points and number of plots for graph and chart
Hi guys,
Can somebody explain to me why i get when i run   Vi number 1  2 plots for each chart and graph with 6 points but when i run vi 2  i get 4 plots with 1 point each execution assuming that the same logic is applied to both Vis.
Thank you.
(3,118 Views)
Accepted by Med092
When wiring arrays to charts, it is assumed that each row are multiple points of a plot.
You either need to transpose the 2D array or right-click the chart and select "transpose array".
(3,107 Views)
Accepted by Med092
You have the Transpose Array turned on for the chart in VI2, but not for either plot in VI1.
(3,099 Views)
