Now I am using DSP test integration toolkit and LV_TIDSP_toolkit examples downloading from NI site. My CCS version is 3.3 and DSK is eZdsp-spectrum digital, but running the filter example i.e.. Filter_eZdsp2812 result error.
I am using DSP test integration toolkit and LV_TIDSP_toolkit examples downloading from NI site. My CCS version is 3.3 and DSK is eZdsp-spectrum digital, but running the filter example i.e. Filter_eZdsp2812 result error.
can anyone clarify me about the proper method of this connection or send me an illustrative example file,  If it is possible.
Your kind is appreciated in advance and it is kind of you if you help me to solve my problem.
With Best Regards.
Mohammad Masoud Namazi,
(2,758 Views)
Accepted by masoud65
Hi masoud,
                     No need to include this much text in the subject line.It should be precise and must convey what the content is.
Thanks as kudos only:)
(2,747 Views)
I am using DSP test integration toolkit and LV_TIDSP_toolkit examples downloading from NI site. My CCS version is 3.3 and DSK is eZdsp-spectrum digital, but running the filter example i.e. Filter_eZdsp2812 result error. can anyone clarify me about the proper method of this connection or send me an illustrative example file, If it is possible.
Your kinds is appreciated in advance and it is kind of you if you help me to solve my problem.
With Best Regards.
(2,737 Views)
