Not enough memory to complete this operation
@mcduff wrote:
For the hours measurement you need to add a Quotient and Remainder Function before the case structure, otherwise 12 AM and 12 pm will be incorrect.
That's one (of many) reason(s) I prefer the 24 hour (or military) format for any timestamp-string formatting…
Message 31 of 33
(855 Views)
GMT as well.  Then no issues with Daylight Saving time.
Bill
CLD
(Mid-Level minion.)
Message 32 of 33
(843 Views)
You have at least 1 for loops that gets it's N from a converted double.
If a double is +Inf or NaN for whatever reason, the N (a I32) becomes 2147483647. That will (probably, haven't tested) give you an out of memory on a 32 bit LabVIEW if there's at least 1 auto indexing output.
LabVIEW 64 bit will gladly stall your system for minutes to comply, and sometimes succeeds.
Message 33 of 33
(834 Views)
