Not enough memory to complete this operation
It doesn't always take the same time to increase, but this time it took about 1 hr (quite faster than before). And I feel like something is stacked to the LabView.exe after this sharp increase. Even if I stopped running the LabView, the increased memory usage is maintained and the response gets really slow.
Message 11 of 33
(2,557 Views)
Does Labview remaing running in the background, after you supposedly exit it? Does it still show in the Task manager?
Message 12 of 33
(2,542 Views)
If there are unclosed library calls then those could remain in memory.
ALE Consultants
Message 13 of 33
(2,534 Views)
When I stop running, then it stops running and doesn't remain running in the background. But the increased memory usage (like 1,000,000K~) is maintained. And I exit Labview (doesn't show in the Task manager anymore) and reopen/re-run the program, the memory usage starts from 100,000K~.
Message 14 of 33
(2,502 Views)
My guess is a reference leak somewhere. It's hard to tell from your block diagram. Something like a new DAQ task continuously being made without the previous one being closed and cleared.
Message 15 of 33
(2,495 Views)
 There is or used to be a nice Knowledge Base article on working with large data sets in LabVIEW.
I'll try to find it but, it should be in my tag cloud.  (Used to be in my macros)
Nothing posted in an inline png explains 2Gb+ although you could avoid some data copies, are abusing local variables and have some probable race conditions.   A refactoring is warranted!  Call for a consultation if, your boss can afford me.
Heck, I'd give a cut rate to an academic institution.
"Should be" isn't "Is" -Jay
Message 16 of 33
(2,486 Views)
Is this the one, JÞB?
If it is a reference leak and you cant find it, DETT can help you to find it. But if the design is bad and there are race conditions, that might not help you, so you may need to refactor anyway just to be certain that there is no reference leak.
Certified LabVIEW Architect
Message 17 of 33
(2,474 Views)
Would a reference leak persist even with Labview closed?
Message 18 of 33
(2,468 Views)
From the OP:
"When I stop running, then it stops running and doesn't remain running in the background. But the increased memory usage (like 1,000,000K~) is maintained. And I exit Labview (doesn't show in the Task manager anymore) and reopen/re-run the program, the memory usage starts from 100,000K~."
From the OP's comment, once LabVIEW is exited the memory is no longer allocated. When the OP just stops the LabVIEW program the memory is still allocated because LabVIEW is still running, just not the OP's program.
Message 19 of 33
(2,449 Views)
Yes, that's correct! And I'm trying to modify the code, but still running the original program. During running, I found a new situation where the memory usage is changed when I change the front panel tab. On my main program front panel, it has several tabs to control the program. The figure below is the main tab on the front panel to monitor temperature mostly shown on the screen. When this tab is shown on the screen, the memory usage sharply increases at some point up to 2,500,00K~. And when I click another tab, the memory usage decreased to ~1,500,000K. It's still high, but I found this situation several times. Unfortunately, 1,500,000K memory usage is maintained. I tried to clear the chart on the main tab but it didn't show any difference.
Message 20 of 33
(2,440 Views)
